June 21, 200917 yr does anyone know of a suitable replacement gear lever for a silver engined mk2 beamish suzuki RL250 thanks in advance tony
June 21, 200917 yr Hi there, I have a black engine Beamish and I fitted a bendy-end lever from a RM . I'm quite sure that the diameter and splines will be the same on both models and also several other models such as the TS etc. I hope that this will be of help to you.
July 6, 200917 yr Hi Tony, The GasGas TXT and Pro use the same spline as the Beamish but your first port of call should be Crooks-Suzuki.
