September 25, 200917 yr Is changing the fork oil as simple as getting the old oil out and the new in? are there special steps to take? 330 ccs a leg right?
September 25, 200917 yr Yeah that's pretty much it, use the oil height (145mm air gap) rather than the oil amount as it is impossible to get all the oil out without full stripping and cleaning. It's easiest to undo the drain bolts with a air impact wrench as the inner sometimes spin so they won't come undone, you'll need a special tool to undo the fork caps to fill them up with fresh oil, I use a appropriately sized bolt and 2 lock nuts, if you haven't got a impact gun it might be easier for you to take the entire fork leg out and drain the oil out of the caps.
