October 7, 200917 yr Hi - i have just bought a 2000 290 and removed my rear mud guard to check the filter and noted that from the rear the rear sub frame arm that holds the mudguard is a different shape to the part that holds the exhaust pipe, and i wonder if its had a clout? The left (from the rear) is almost square, whereas the right (exhaust side) is a smooth arc. should they be the same ? Cant seem to find a photo anywhere of the rear that would help me. The mudguard is on the skew, but i assumed that its because it has the inevitable creases in it. Anyone know of a source for them too? I dont want to pay
October 8, 200917 yr Hi - i have just bought a 2000 290 and removed my rear mud guard to check the filter and noted that from the rear the rear sub frame arm that holds the mudguard is a different shape to the part that holds the exhaust pipe, and i wonder if its had a clout? The left (from the rear) is almost square, whereas the right (exhaust side) is a smooth arc. should they be the same ? Cant seem to find a photo anywhere of the rear that would help me. The mudguard is on the skew, but i assumed that its because it has the inevitable creases in it. Anyone know of a source for them too? I dont want to pay
