November 11, 200917 yr Hi there, has anyone tryed a Yz 125 Clutchcase on a TY 175 or a Yz 250 Clutchcase on a TY 250.It must be the aircooled yz modell from 1976-1978.They look nice,because they have no oilpumpcover.Anyone got an idea. Chrs:Mike
November 11, 200917 yr Hi Ducman, It may well work, there was a rider at this years Don Smith memorial trial with a Majesty 200 that had a clutch cover with no area for an oil pump. It looked very smart and trick! Unfortunately I did not have a chance to talk to the owner. See if you can check the clutch cover gasket and clutch drum part numbers of both bikes. If they match your in. I know that this case trick works on the Kawasaki KT, using the early KX400 clutch cover. Regards
November 11, 200917 yr Hi Ducman, Got the same idea when I did saw pics of nice all black TY125, 175? chrome stickers. Nice YZ pics here: http://yz125x.blogspot.com/ I have started a slomo rebuild of a 175 (4 barrel studs 1975?) Mapping now all OEM part no..before research for improved replacement parts.. It might be so that Wis do not offer dyke styles, not that importartant for trials even though std at moderns. BR, Pat Edited November 11, 200917 yr by Pat
November 11, 200917 yr Yes, YZ125 and IT175 clutch covers from C to F model at least and maybe later fit perfectly on TY175 bottom ends Sorry I don't know if there are any 250 or open class MX, YZ or IT (premix type) clutch covers that fit the TY250 bottom end. I suspect the TY250 bottom end is most similar to the trail/MX motors made from 1968 to 1973 and the production motors of that era had oil pumps.
November 12, 200917 yr Author First thank's everybody for that quick repley.So i can have a look for yz 125 Clutchcovers.For the 250 we have to see.@monoped:Well,the thing with the parts numbers on Yam's is not that easy then on Kawa's.The truble with the Yam parts numbers is that if it is the same spare part for a othe bike,they will also have a differnet parts number.I can not understnd that system.So for example,if i go to the local Yam dealer and wanted to order clutch plates for a TY 250 the Computer says no.If i want to order the plates for a XJ 550 road bike,the computer says yes.Same part and cheaper price,but different number.So sometimes it is good to know that they put the same parts in other bikes. Chrs:Mike
November 22, 200917 yr I just bought a 1977 IT 175 D cover off E-Bay and it does not fit my 1975 TY B. There is one bolt hole on the top that does not line up.
November 23, 200917 yr I used to put a YZ125 Clutch Cover on my TY175 and went straight on. The Oil dipstick would no longer work as it went in directly over the clutch. I used to cut the dipstick blade off. If anyone is after a copy of the TY175 Workshop manual click here.
