December 6, 200916 yr Hi All, i am looking to get a rack to bolt onto the back of the car (Golf). can anyone recommend, by experience a good make/model, and dealer. cheers paul Edited December 6, 200916 yr by paul w
December 6, 200916 yr I beleive Dave Cooper racks and trailers are the best available. Will hold a mont on no bother! http://www.davecooper.co.uk/ Cheap too! Edited December 6, 200916 yr by shercoman2k8
December 7, 200916 yr which golf are you looking to fit the towbar to? I have fitted towbar's to two golf mk V's and one mk IV, they are very easy to bolt on, bumper cover off, remove and through away the rear strengthening bar, slide in the towbar, bolt it up through the VW provided holes, blind threaded holes already preped at the factory. The only problem comes with the electrics, as the mk V has a canbus system so you need a special relay box, (which you can buy on ebay) which reads the low power to the lights and switches a feed from the rear boot cigarette lighter socket (at least this is what I did). Hope that helps, otherwise any decent garage (or autoelectrician) should fit easily and no more than 1.5 - 2 hours labour max, @ ~
December 7, 200916 yr I had a rack fitted to my golf and to be honest would look at another way of transporting the bike. Because the rear bumper is so high I had problems with the gear lever and footrests rubbing against the paintwork, I even had spacers fitted to gain more room but still ended up with big holes in the bumper. The racks sat in the shed if you want to try one PM me.
December 8, 200916 yr Author i know a racks not perfect but nowhere to keep a trailer now. thanks for the replys. dave cooper it is.
December 9, 200916 yr Does any one know if a rack is available for the removable type tow bars? I have an A4 Avant fitted with a Westfalia removeable towbar. I spoke to Dave Cooper and his do not fit. I haven't really got room for a trailer and a rack would have been ideal. Thanks Steve
December 9, 200916 yr Does any one know if a rack is available for the removable type tow bars? I have an A4 Avant fitted with a Westfalia removeable towbar. I spoke to Dave Cooper and his do not fit Not likely Steve - there is too much flexibilty in a removable towbar. You might be better just biting the bullet and changing it for a fixed towbar / rack. There are a couple of decent retailers in Worksop you could approach for the conversion (Tranker lane and Eastgate) Edited December 9, 200916 yr by Fivemeister
December 9, 200916 yr He won't advertise here himself as he respects the TC forum rules on advertising, but it might be worth having a word with Stuart Cameron of Bradford & District. Top bloke who works his a*** off for the sport and has an understanding of the needs of Trials riders. His website is http://www.autowbars.co.uk/
December 10, 200916 yr I have a fixed rack mounted bike rack its really good got myn for 20 pounds fle bay has lots of new or new ish ones cheap
December 11, 200916 yr Hi, I have a Witter removable towbar on my A4 Avant, and there was an option for the removable towbar with the two hole flange - maybe you can get one for yours? The rack can bolt right onto it. Had good advice on here - go for a trailer if you can because you'll be knackered - I was!. You can find ones that are barely bigger than a bike and can be stood up on end.
