December 18, 200421 yr Just bought a tlr 200 with apparently the wrong carb. It is a keihin but I think perhaps too big. After the bike has run for a short while it chokes up. Can anyone let me know what carb I need and where I might get one from? Also what jet size it should have etc. Cheers
December 18, 200421 yr Straight from the Honda manual Type 660C Float level 24mm Main Jet 98 Slow Jet 40 Needle in 2nd notch Air screw 1 7/8 out This is not for the Reflex (I dont know if the yare the same) have a search on the web under TLR200 and you wiill find some more detailed information
December 19, 200421 yr Ellastone may have one but they are a bit of a rip off, they know how to charge for TLR bits.
December 19, 200421 yr Author Thanks for the prompt advice lads. I did try Ellastone but they didn't have one. If they do get one it will be
December 19, 200421 yr I'd say, if your rich enough to buy a TLR your rich enough to buy the bits too
December 19, 200421 yr Try to find out what diameter the TLR200 carb is - I suspect that it is a 22mm carb. If that is the case visit your local breakers and get a carb from a XL125S or XL185S (or even XL100S!), all are 22mm. They are the same basic design and should not take too much setting up. I would also be inclined to try a carb from a CB125 (single) or CG125 from the early - mid 80's If you go for the XL125 carb even the main jet is the same size.
December 19, 200421 yr Author It is a 22m carb. The local bike breakers sounds like a good idea. I wonder how much a carb will cost if I don't mention those 3 letters (TLR). Cheers mate
December 19, 200421 yr Your breakers probably won't know what a TLR is - if they do and they have a 250 tank let me know!!!
December 20, 200421 yr Have tried David Silver Spares or you could try here = http://stores.ebay.com/Vintage-Motorcycle-...displayZ2QQtZkm For an alternative carb!
December 20, 200421 yr How about a bit of reverse engineering ? If the TL Carb works well on a Cub and a 22mm PHBL Dellorto also works well on a Cub then QED the 22mm Dellorto should also work well on a TL ?????!!!!!!!!!!!!
April 8, 200521 yr As far as I am aware There is a slight difference to the tank mounting on 250 & 200. The 250 has a metal strap which slips over the frame 'mounts' & positions the rubber 'caps' which mount the tank about 2" higher up than on the 200. The 200 tank mounts on the frame directly via rubber 'caps' on the frame 'mounts'. Hope this makes sense - its easier to see than describe. I tried a 200 tank I have as a spare on my 250 & found the difference. It would be relatively easy to make up something to suit 250 type tank mounts.
