December 28, 200916 yr Hey all, New to trials, new to motorcycles... My recently pruchased 1976 Ty175 has been starting easily and running well for a week now, however the last two times out it stalled out as it idled to a warm up. I start it with the choke out, wait to it getys to a nice steady idle then pop the chke back in and get on my way. Now it barely gets to a steady idle then stalls, and will not start again. The last time this happened (or last time I got it started) I immeadiately pushed in the choke got it in gear and tried to keep it running under throttle. No luck though, it quickly died. Any ideas - i tried a new plug by no change.... Thanks
December 28, 200916 yr Sounds to me like it is short of fuel, check fuel line i.e. pull pipe off of carb end and check for plenty of flow, next step is strip and clean carb, probably dirt somewhere between fuel tank and getting into engine so you might have to systematically go through it. hope that helps a little.
December 28, 200916 yr almost certain to be on the carburation side - check the obvious first - is it fresh fuel, clean the air filter, check fuel delivery from the tap and through the fuel line, is there a filter in the tap ? check your choke isn't sticking then check your jets are clear especially the idle jet which is mostly used on low revs and check your float bowl level fingers crossed Tony
December 28, 200916 yr Definately sounds like one of the jets. Clean out the pilot jet especially well. If you've got an air compressor blow it out with air from that. If you haven't you may have to resort to more crude methods like using a bit of wire. I know people may slate me for saying using a bit of wire but we don't all have fully equipped workshops at our disposal. go delicately as the bore on some of these jets are tiny. If after you have cleaned up the carb and it is still not running unless the choke is on then it may be the crankseals are sucking air in and need replacing. Make sure your airbox isn't clogged up too. let me know how you get on.
December 28, 200916 yr You definitely need to be running a fuel filter in an older bike (well any bike). You have probably sucked some dirt into one of the jets. That idle jet is really small and doesn't take much to plug up. Alan
December 28, 200916 yr I would go for the condensor as B40Rt says,i hab it a few times on old Yams.Starts easily and when it was hot and you want to sratr again no chance.New cold plug and it fired up again.It was the condesnsor. Chrs:Mike
May 4, 201016 yr Author Thanks guys - I was finally able to sort the problem out. After many carb tear-downs I discovered the float bowl needle was sticking. So I was getting fuel into the float bowl, but then the needle would stick once the bowl was full. I'd get the bike going until the fuel in the bowl was all used up and then get no more due to the stuck needle. Very annoying little situation...
