Revs Are To High On My Ty 175
my ty175 is reving to high on tick over and the tick over screw does not stop it any ideas any body,,,,thanks tom
more than likely drawing air from the inlet side check all your connections and the rubber inlet manifold
I presume the slide is seated at the bottom of the carb? If not then the cable would need adjustment.
Sorry if this sounds simple but it can be easily missed.
Just to add to the checks with regards the too much air, where the oil lube system connects to the carb, if this has been removed I have known the pipe not to be blocked off as it should be. This would cause the high revs.
Is it weather related? ice? in cable even in carb at seat of slide..once had that on a gas gas ..think of the windchill factor
