Amal
Hi,
Will kindly ask if any of you do know the mesaurements of threads at the back end of Amal MK1 body?
I do need to extend the rear end of the carb by ~3" (have seen such solutions somewhere, made of nylon..on a Bantam)
Do you think any tube ( for other assemby..?) with matching threads inside is available?
I might can use a std part, Polished Alloy Bellmouths, but dont know if its perfect to seal the air boot to a chone.
BR,
Edited by Pat
Pat,
I needed to move the AMAL away from the cylinder on my Bantam (was vapor locking). I found that the intake manifold for a Norton twin (it's a seperate piece for each cylinder) fit perfect and extended it about 3".
just something that worked for me.
Alan
Thanks a lot Wayne and Alan.
Cheers,
Your're welcome.
Alan is right though, you should look into tuning the inlet length between carb and cylinder. I seem to recall from dabbling with Bantams some years ago that they worked better with a longer manifold.
Wayne...
