Bultaco Forks
Did Bultaco make 38 mm forks. Betor type.
Around 1983.
I need details of the damper assembly etc
As far as I know, Sherpas and Pursangs only had 35mm forks, the Sherpa forks being pretty much the same as Ossa, other than the leading axle.
To clarify you should contact Dave Renham at Bultaco UK as he is the leading UK Bulto specialist
http://www.bultacouk.com
SWM Jumbo's used 38mm Betor forks on the 1984 model......maybe a set of those has ended up on your Bultaco?
Martin
