theshercorider Posted February 7, 2010 Share Posted February 7, 2010 I was out practicing today when unknown to me my rear pads had completely worn out and because of the sudden drop in performance I presumed it would be a leak or similar, however I found it was the pads and that they had left marks in my disc rotor, will I be ok just to replace the pads? Cheers Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted February 7, 2010 Share Posted February 7, 2010 The new pads will bed in to the shape of the disc, don't try to do it all at once as the extra heat generated by the grooves will glaze the new pads. Fit the new pads and bed them in as gently as you can. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted February 8, 2010 Share Posted February 8, 2010 I've done that at the SSDT.....the disk didn't come right until i sanded it. Remove the disk and get the junk off. Quote Link to comment Share on other sites More sharing options...
zippy Posted February 8, 2010 Share Posted February 8, 2010 Depends on how deep the grooves are. Minor clean disc with some wet/dry fine grit sandpaper, I soaked the paper with WD-40 when I cleaned mine up. New pads will "Bed in" eventually. Deep grooves pitch it and get a new disc. Quote Link to comment Share on other sites More sharing options...
