fulmine Posted March 5, 2010 Share Posted March 5, 2010 Has anyone had problems with the gear shift on the Sherco 3.2? Quote Link to comment Share on other sites More sharing options...
sirhc Posted March 5, 2010 Share Posted March 5, 2010 Of the 3.2's that I've had, no shifter problems Quote Link to comment Share on other sites More sharing options...
bobtlr Posted March 5, 2010 Share Posted March 5, 2010 hey, no problems here best regards Quote Link to comment Share on other sites More sharing options...
tony27 Posted March 5, 2010 Share Posted March 5, 2010 What problem are you having exactly? Shercos have a groove on the gearchange shaft where the pawl is welded on which allows the shaft to twist or break rather than cause damage to the gearbox internals, if you're struggling to select gears have a look at how close the lever gets to the bashplate when moving downwards If thats the problem its a easy fix, order a new shaft(about 40gbp) & gasket then pull the clutch off & change shaft. All very self explanatory when you do it Any problem other than that & you'll need to explain the symptoms better Quote Link to comment Share on other sites More sharing options...
copemech Posted March 6, 2010 Share Posted March 6, 2010 The gear shift mechanicals are no different from a 2T. What is the issue? Quote Link to comment Share on other sites More sharing options...
fulmine Posted March 7, 2010 Author Share Posted March 7, 2010 I'm watching the ads Sherco 3.2 and have already used two owners who tell me they have replaced one of the gear because of the second crack, the other had changed gears shift well without specifying which ones and why. So I began to suspect that the change of the Sherco 3.2 might have inherent problems. Thans all. Quote Link to comment Share on other sites More sharing options...
