Frame Guards, Are They Worth It?
Im hopefully buying an 09 sherco and i wondered if the frame guards are worth the investments or not...
good points bad points all welcome...
60+ views and nobody has an opinion of them?
does that mean nobody uses them?
I have installed the jitsie frame guards on an 09 and like them, would do again !
The way I see it......it keeps the bike in better condition which makes it easier to sell on and probably get slightly more for it! so I say yes!
Its a trials bike, why put bits all over it?
id have thought that was fairly obviouse.... when you work and save up for something is it not normal to want to look after it?
sounds like you just answered your own question Ben
Edited by easytigrrr
I use them some say you have to be carefull not to get mud/grit under them (trapped twixt them & frame) because you could do as much harm as good. Steve Saunders supplies british made parts for most bikes.
Edited by chewy
