Kill Switch
ive just got a 200 sherco, and the kill switch wire is loose, but i need to know where the wire connects to, is it to the coil, the diagra on the sherco site is in spanish and i cant understand it, is there any english diagras any where? thanks colly
www.rypusa.com
Look for the instructions for installing the simple harness.
Got to go ride now, will find it tonight if you do not...
Black wire at coil, green with yellow tracer, ground to frame, if kill switch has two wires.
One wire kill switch, black wire from coil grounds on the bars when you push the button, poor switch will often give you a shock when wet, it's hard to press a button that is shocking the sheet out of you, two wire system most recommended in my opinion.
thanks, got it sorted now :)
