Wont Start When Hot
hey, my sherco 02 200cc just wont start when it is hot, itl start perfectly when it's cold, but once it's started it takes some what 10 kicks and sometimes starts. its just had the coil, and the whines rewound, and compression seal, and piston rings befor i bought it so i should think compression is ok. the spark seems strong enough aswell. when i took the spark plug out it was oilly, is it worth gettin a new plug in it, also what plug should i get. could it be to do with the carb settings? one last question, on the air box, does it suppose to have a cover on it, and mine is just a filter, with a allen key to hold it in place. thanks colly :)
It's ALWAYS a good idea to try a fresh plug.
Gap it at .5mm
NGK BP5ES
Easy cold starting+wet plug+hard hot starting=probably too rich jetting
Test for clogged pilot by trying hot start with some choke, if it starts easier with some choke clean pilot jet.
yes i think it does, i'll try and give this ago, also it runs perfect once started can this still be the problem
