Ty175 Shocking Problem
Hi, Not having much luck got similar problem with my fantic as well, I got a shock of the HT lead when investigating poor running, does this indicate a problem with an earth perhaps.
Well, couple of questions: Are you running a battery in the bike? Was the bike running or turned off when you were shocked.
If it was running you probably just don't have a very good insulator around the lead.
Alan
  • 3 weeks later...
Your HT lead is goosed, replace it and it will run a lot better along with you not getting zapped !
Thanks for all your helpful replies, fitted new length of ht and voila all sorted.
Thanks again
