Fork Adjustment
Hi all
Can anybody give me the ball park adjustments for my forks,one fork has c on it,the other r.
Cheers
Assuming it is a 2006 or later bike the right leg has the damping adjuster (small brass adjuster on the top of the leg) turn this adjuster clockwise to slow the fork down, anti clock wise to speed it up, I have mine around 2 clicks in from full out. The left leg has a allen key adjuster on the top of the leg turning the clock wise alters the amount of pre-load on the spring so therefore alters your ride height when your riding, this is called sag.
Thanks so far.......................but i need to use C/R on the first repl?????????????
Shercos have never had separate compression and rebound damping adjusters
Are you sure ?????
I think so, well all the 2 stroke bikes haven't since 2002 anyway.
I'll think your find all the bikes from 2006 on have..
Right leg is for rebound and left leg is for compresion..As you said above..
Left may have the compression damper in it but it not externally adjustable, only the preload is able to be altered.
To alter the compression damping you need to alter the oil weight(viscosity)or height
