September 17, 201016 yr Hello, Yesterday I bought my new Sherco and set up for my weight. I measured front rider (race) SAG approx. 1/3 of total travel with max. preload and more then 1/2 rear rider SAG with max. preload. I read that rear sag must be approx. 1/3 of total travel, but I measured that rear static SAG (without rider) is 1/3 of total travel, is not it strange? Sherco have 55 mth. Where can I buy new stiffer springs for my Sherco? Thank you for repaly and sorry for my English. PetrS.
September 17, 201016 yr it sounds like your rear shock unit may have failed these did have a problem on 08 models check with your dealer
September 17, 201016 yr Author OK, I try contact dealer, but do you know, where to buy front and rear stiffer springs? Thanks.
September 18, 201016 yr Forget about all that race sag stuff. How much do you weigh? Unless you are over 100 kilos, the standard springs should be fine. Use the STATIC SAG(weight of bike only) method and set the bike (spring preload) between 0 and 30mm dependant upon your weight of 100-70kilos . I think this is a better guideline. Sherco does not seem to sell heavy springs, one must have them made to order by a spring supplier. Thus, unless you are running a custom shocker like an Ohlins or TRP, I have not seen any heavy springs offered of late. Yet there may be some dealers or importers that have had a batch made up. Fact is, even much heavier riders get along well on the stock springs in most cases.
September 20, 201016 yr Author Hello Copemech, I have about 107kg with gear and helmet. I found this: Spring But I don't know, where I get front stiffer spring :/ Have you any idea? Or do you think that I don't need front stiffer springs? : ) Thanks for any reply.
September 21, 201016 yr Hello Copemech,I have about 107kg with gear and helmet. I found this: Spring But I don't know, where I get front stiffer spring :/ Have you any idea? Or do you think that I don't need front stiffer springs? : ) Thanks for any reply. Front is usually a non-issue, seem fine. Well, that spring is for the TRP shock, and doubt it will fit the Olle. Buying a TRP shock or an Ohlins, you should have the option of springs, and this is a premium setup. To get a heavy spring for ethe standard Olle, one would need to probably source it through a MX suspention specialty shop in you area. Springs are built to spec(add 10%) and it is usually not too costly, other than downtime, for them to take yours and do the deal for $100 or so. I do not know where you are located. If you are in Spain, you may check with Paxau Racing to see if he has anything to help. Edited September 21, 201016 yr by copemech
September 21, 201016 yr I know Topfun used to list a heavier spring for shercos Their website does have a small trials catalogue still which lists both a complete olle shock & heavier(I think) spring Part number TF4015 , 7.5kg spring , price 55.59euro If you can find a stockist of their stuff near you it may be worth asking if they're able to help you Edited September 21, 201016 yr by tony27
September 21, 201016 yr Author Front is usually a non-issue, seem fine.Well, that spring is for the TRP shock, and doubt it will fit the Olle. Buying a TRP shock or an Ohlins, you should have the option of springs, and this is a premium setup. To get a heavy spring for ethe standard Olle, one would need to probably source it through a MX suspention specialty shop in you area. Springs are built to spec(add 10%) and it is usually not too costly, other than downtime, for them to take yours and do the deal for $100 or so. I do not know where you are located. If you are in Spain, you may check with Paxau Racing to see if he has anything to help. Ok, I'll try to find a local manufacturer of custom springs. Thanks for advice. Btw. I'm from Czech Republic.
September 21, 201016 yr Author I know Topfun used to list a heavier spring for shercosTheir website does have a small trials catalogue still which lists both a complete olle shock & heavier(I think) spring Part number TF4015 , 7.5kg spring , price 55.59euro If you can find a stockist of their stuff near you it may be worth asking if they're able to help you Thanks, I'll write them. But 7,5kg? It is a bit much, no? I have 7,2kg on my supermoto and it's super hard on rear. I think that for trial need about 4 - 5 kg.
September 22, 201016 yr Thanks, I'll write them. But 7,5kg? It is a bit much, no? I have 7,2kg on my supermoto and it's super hard on rear. I think that for trial need about 4 - 5 kg. All this will depend upon the travel/ lever ratios and such. Cannot compare directly to a supermoto. I do recall Topfun offering a spring for the older models at one point, yet I think the dimentions have changed on the latter models. Hopefully they might tell which years theirs will fit.
September 24, 201016 yr Author All this will depend upon the travel/ lever ratios and such. Cannot compare directly to a supermoto.I do recall Topfun offering a spring for the older models at one point, yet I think the dimentions have changed on the latter models. Hopefully they might tell which years theirs will fit. Ok, thanks for advice, I'll contact Topfun for stiffer spirngs : )
