September 27, 201016 yr I switched from using the stiff rubber fuel line to using Tygon PVC fuel line tubing and found I can get access to the carb choke lever much easier now. Tygon F-4040A is sold throughout the world and can be found at most well stocked auto supply houses. This is their 3/16"I.D. tubing (about $2 US per foot) and I'm using the flat steel spring clamps for a very secure fit on all connections. Note the OEM Honda fuel filter has plenty of space, now. I like the fact that I can see the gas so I know it's getting to the carb. Edited September 28, 201016 yr by scooterspal
