October 9, 201016 yr Hi The Oil pump on the TY80 I'm rebuilding is disconnected, but still in place. To remove, does it simply unbolt, or do you need to split the cases ? The pump itself has been removed but the driveshaft won't come out, and the driveshaft rotates with the engine ? Any help appreciated cheers John
October 9, 201016 yr remove clutch cover and remove gear from cover! you will need to make a blanking plate and gasket to blank off hole where gear was!
October 9, 201016 yr Author Thanks for that ! So take the small cover off then remove the pump, then remove the whole clutch side cover ? I have a blanking plate - I bought along with a fortune's worth of other spares ! .... but I'm sure Christmas day will be worth it cheers John
December 6, 201015 yr If the oil pump and shaft are left in place, but the plastic gear and associated washers/clips on other side of clutch cover are removed. Would that be basically the same as removal and a plate put in place?
