November 18, 201015 yr Hi Guys, I was just wondering if anyone would be kind enough to give me a brief description of how to rebuild the right fork leg on a 2007 Sherco. Been having a few problems re-assembling the fork. Cheers.
November 18, 201015 yr Here is the link for the Sherco site......and Wayne has a section on fork seal relacement that may help. He also has other articles that might help you in the future. http://www.sherco.com/wayne_corner.html
November 18, 201015 yr Author How far have you taken it to bits, which bit are you struggling with? The Damper unit is fully out of the leg. The main problem is tightening the bolt at the bottom of the leg to enable me to put the oil in.
November 18, 201015 yr The Damper unit is fully out of the leg. The main problem is tightening the bolt at the bottom of the leg to enable me to put the oil in. is there a small cup in he bottom of the leg,if so it needs to be correctly seated at the bottom of the leg, before re fitting the allen bolt
November 18, 201015 yr Author is there a small cup in he bottom of the leg,if so it needs to be correctly seated at the bottom of the leg, before re fitting the allen bolt Yes there is, After seating it, there still seems to be play in the damper unit after fully tightening the bolt. Can't work it out.
November 19, 201015 yr Yes there is, After seating it, there still seems to be play in the damper unit after fully tightening the bolt. Can't work it out. have you got all the parts check out what is inside then start slow time re fitting, cant think what the problem can be...
November 20, 201015 yr Have you got a new sealing washer on the bolt, it's just a thick copper washer. Otherwise have you got the wrong length bolt or got something stuck inside the hole.
