Fork oil info required
So, my TY250R has a leaky seepy issue with the front forks :rolleyes: I've some fork seals in my ebay watch list and just need to know the air gap when I re fill the forks with fresh oil?
Also what oil do you learned peoples use in your ty forks?
All help much appreciated as I've been cleaning out the seals with a feeler blade which works well for a while though it seems the seals are past their oil holding best.
Not sure if your 250R takes the same as my 350N, but those spec.'s are 99mm or 3.9" oil level of 10 wt. fork oil.
Jon
Jon
Cheers Jon, sounds about right to me. I'll get the seals ordered and check what oil I have in the garage.
