05 125 with kehin carb
Hi folks,
Recently picked up an 05 125 Sherco with a kehin carb on it for my girlfriend (she can't kickstart my 250 rev3). Bike starts ok, but fluffs badly off idle. I've removed the carb, cleaned it thouroughly, altered the float tab to stop it pouring fuel out and refitted it (which was a pain). Plug looks reasonable, but with this cold weather I didn't want to mess with the jetting blindly if some other kind soul already had the perfect set up. Cheeky I know, but you never know until you ask.
Ta
Mark
Here's my old collection of notes on this...
Jetted Sherco125 - 38/125 Standard Needle
Howard Wallace
I`m running a KeiHin with 38 pilot, 110 main,JJH Needle.
The 125 + 200 have a different crankcase casting, with a shorter length where the reed block mounts.This makes it a bit tighter, and the float bowl drain hex needs a chamfer to clear the top of the gearbox , also need a hose from carb to airbox about 50 mm long. I use the radiator hose off a car with the right diameters. It`s a bit of work to fit up, but the performance gains are well worth it.
Cheers, ShercoH
45/118 - stock unleaded fuel.
Cheers guys, fitted the b*stard last night. Haven't got my hands on jets yet, running standard 45/125 jets, JJH needle, clip in the middle position.
Air screw half a turn out and its near right, any further out and it just bogs down when you whack the throttle open from tickover.
But I will say it's a touch warmer over here at the moment :P ...hope you have a nice warm garage to work in?
Best of Christmas balance.
Neo
Edited by Neo
Neo
Cheers for that Neo, wrote down what jets are in mine, but the note is in my (centrally heated) garage next to the bike! Will compare this evening when I get home.
Ta
Mark
Now ya talking :thumbup:
I remember many night working on freezing cars over there :frosty: ... and sometimes it was so cold I couldn't even think straight :madnoel:
Best of balance.
Neo
  • 4 weeks later...
Just remembered that I didn't come back to this, so if anyone was wondering:
The jetting is 45 pilot, 122 main, JJH needle on the middle notch.
After a few more runs with known fuel (Rock Synthesis 2 at 1.5%) shes a lot crisper. My g/f rides around at very low throttle, so have had to teach her to blip it to keep it sweet, whereas with me riding its absolutely fine.
Mark
Enjoy :thumbup:
