swing arm
hello all can anybody tell me whats the best way to seal the holes were the greas nipels go the only reason im sealing them is because ive put the rolling bush kit in ive tryd clear silicon and it just keeps coming out when its dry is there somthing else what would work?
Try a headless screw or grub screw that fits together with loctite 603, you might mill away the apex of the screw first. Maybe it also works with loctite 243, (the blue liqued), but i would not bet on it, because there are only some threads. The 603, (green one), is a real glue but difficult to get loose again.
thanks for the addvice wheres the best place to get loctite?
Befor I post You any adress from the continet use google with:
"loctite 603" buy
One hint this stuff is expensive, you can get a very small tube from Graupner, thru Amazon:
- 50ml Loctite around 46
  • 2 weeks later...
My M159 has a self tapper at the front of the l/h swingarm tube and a bolt in the front r/h side, should they be grease nipples? Do you know what size? Are they needed to lube the bushes?
Thanks
Mick
Thanks
Mick
What sort of bushes are fitted, silent block (ie rubber) dont need lub.
Im not sure what they have, they are quiet, so I haven't gone near them. As far as i know they are standard, but given the self tapper/bolt scenario, I have no real idea.
Mick
