February 20, 201115 yr How far should forks be placed above the triple clamp on a 175 some have said even and some say 14 mm above??
February 20, 201115 yr The right height is whatever you think works best. Moving them up or down changes the steering angle, steering trail, wheelbase, ground clearance and how much they flex around. The standard height from the factory is 20mm protrusion above the top clamp.
