April 4, 201115 yr My 02 sy250 is making a loud whirring noise from the clutch, not the typical scorpa noise, something different, changed fluid and everything.
April 4, 201115 yr That sound is often an issue with the crank. Not a great sound, say if the throttle is jammed open and the bike has revved its bits off the crank separates. Some Birkett fettled bikes had the motors split and cranks tac welded to stop this. I hope im wrong..
April 4, 201115 yr Author I hope its not either, the bike runs super, compression, power, clutch, its all great, just a sound coming from the shifter side case.
April 5, 201115 yr Author Also, I just got the bike, and it had the clutch basket removed and that seal replaced, could it have been assembled wrong? I usually do my own wrenching, but it was done before I received the bike so I don't know what was done? And I'm brand new to scorpa.
April 5, 201115 yr That sound is often an issue with the crank. Not a great sound, say if the throttle is jammed open and the bike has revved its bits off the crank separates. Some Birkett fettled bikes had the motors split and cranks tac welded to stop this. I hope im wrong.. This happened to my 03. Sent it to back to the importer and he fixed it. I did't have bar ends installed and the throttle was wide open and stuck in the mud. I tried to stop the engine with the kill switch. Just as it was almost stopped I slipped down the hill, it backfired and twisted the crank. Take off the ignition cover and check the run out of the flywheel.
April 5, 201115 yr Author does it hurt to run it like that? Performance is great, and is the fix permanent? You'd think if the crank twisted it would run different?
