April 7, 201115 yr Hi All my lad has a 36v OSET which we have had for 8 months with no problems. We were competing this weekend and the throttle just cut out. Will reset if turned off and on again but cuts out instantly if throttle snatched or at about 1/3 throttle if wound up very slowly. Shows all 3 lights on throttle and had only run for about half hour after an all night charge so dont think it the batteries . Have had all connectors apart and appear to be ok . Could it be throttle itself or motor controller??? . Problem did occur shortly after bike had been dropped in a stream but motor or electrics were not submerged at all and ran for about ten minutes after before problem occured . Am not electrically minded at all so am open to any suggestions at all Regards Steve Edited April 7, 201115 yr by taz
April 30, 201115 yr The throttle is a Hall-effect sensor. It is fragile, meaning it is easy to damage mechanically. It will go bonkers if you get it wet inside.
