Dunlop tubed rear tyre availability
I am preparing for Scottish pre 65 trial and wondered if anyone knew any availability of tubed Dunlop rear tyres. In the past I have found that with a rigid I have had less punctures with a Dunlop, I have one D801 remaining with a new edge but thought it may be worth asking the question. Thanks
Currently I use 6 psi in the rear although in the past I tried to run a bit lower.
According to my notes I have definitely used Dunlops since 2008 and may have been earlier.
The last year I had punctures was two in 2006, the worst year was three punctures in 2004.
I think the reduction in punctures is driven by many causes,including higher rear pressure, Dunlop tyre, going slower between sections and as I get older getting fed up with changing tubes.
