BSA b175 tuning.
It has been bored out to a 185 and had a electronic ignition fitted and a mikuni carb any advice to make it pick up faster
Flippant I know ..breed it with my Sherco. .Can you advance the timing a bit? might be all you need
Na timing is brilliant I tried a new plug which is softer perfect now
Have the ports been messed with or the piston shortened. I have bored a large number of these but the lad I do most of then for does a lot of extra work on them.
You'ed get interbreading with a Sherco needs to be a gas gas.
No I don think so it has just had a bore out
