May 5, 201115 yr As I simply can't get myself to fork our the 200+ dollars for a new kick start on my TY 175 I have to ask the question - what are my alternatives??? Will any newer model kick starts fit, say something from a newer bike, different manufacturer etc? How about from the TY80? The TY80 kick start look much stronger, albeit a little shorter, and they are cheaper and readily available (at the moment at least). The TY 175 looks (and was) kinda weak... Anyone??
May 5, 201115 yr http://cgi.ebay.co.uk/1976-YAMAHA-TY-175-KICK-START-STARTING-LEVER-W-RUBBER-/330560066040?pt=Motorcycles_Parts_Accessories&hash=item4cf6ea51f8#ht_2097wt_698
May 6, 201115 yr Author http://cgi.ebay.co.uk/1976-YAMAHA-TY-175-KICK-START-STARTING-LEVER-W-RUBBER-/330560066040?pt=Motorcycles_Parts_Accessories&hash=item4cf6ea51f8#ht_2097wt_698 Hi Bo - yes I did see that add, it's actually the reason I asked the question. That is off a TY80, not a TY175. So it fits, but does it fit well enough to be used...?
May 6, 201115 yr Author Try Dt 125/175 Chrs:Mike Hey Mike - ya don't think it'll work. The TY80 kick looks more apt to fit but thanks
May 6, 201115 yr The TY80 kickstart will probably work fine if you can work out how to ride the bike without a right hand footpeg
May 7, 201115 yr Author The TY80 kickstart will probably work fine if you can work out how to ride the bike without a right hand footpeg Ah... funny guy. I was wondering about that as I hadn't seen one in person. It looks like I'll be stuck getting the TY175 kickstart, but it pains me...
May 7, 201115 yr Steve have you priced one from John Cane in the UK? I find it to be economical to buy from John compared with my local (Australian) Yamaha shop for TY175 kickstart assemblies.
May 8, 201115 yr Author Steve have you priced one from John Cane in the UK? I find it to be economical to buy from John compared with my local (Australian) Yamaha shop for TY175 kickstart assemblies. Yes, thanks feetup. That's the direction I'll be taking although I was hoping someone had a stronger alternative. Once received here in Canada it will be close to $200. Not much choice in the matter though!
May 9, 201115 yr As I simply can't get myself to fork our the 200+ dollars for a new kick start on my TY 175 I have to ask the question - what are my alternatives??? Will any newer model kick starts fit, say something from a newer bike, different manufacturer etc? How about from the TY80? The TY80 kick start look much stronger, albeit a little shorter, and they are cheaper and readily available (at the moment at least). The TY 175 looks (and was) kinda weak... Anyone?? Firstly for me would be the above reply, failing that, there is an alternative, not ideal, but does fit. I sourced a kick start lever off an '80's RD250 or 350 Yamaha, its way too long and will actually foul with the exhaust slightly, but more with your right leg when riding. But the pinch bolt on the spline design is far more robust in cast size to the TY one. I tried to heat bend it to shape better, but was just not quite right to kick on then. Go with the original!
May 11, 201115 yr Author Firstly for me would be the above reply, failing that, there is an alternative, not ideal, but does fit. I sourced a kick start lever off an '80's RD250 or 350 Yamaha, its way too long and will actually foul with the exhaust slightly, but more with your right leg when riding. But the pinch bolt on the spline design is far more robust in cast size to the TY one. I tried to heat bend it to shape better, but was just not quite right to kick on then. Go with the original! Thanks Subanator I appreciate the reply. It's pretty hard to replicate the original, and it's most likely the best route to go. I'll check out the RD250/300 though as it may be easier to source out and I like the fact it's stronger. Steve
