May 13, 201115 yr To be held at Emmotts just outside Silsden start at 11:00am. Sections are in and around a rocky stream. All Adult and Youth Classes on Hard 50/50 and clubmans courses.Small Wheels will as usual be running on a separate course. For those needing directions to The Venue you need to go to Silsden via the A628 from Keighley/Skipton or the A65 from Ilkley/Skipton. Take the Main road (A6034) into Silsden. The Road to the Venue is off the 6034 (Silsden/Keighley/Bolton Road) and is called Clog Bridge. This is opposite the Bridal Wear shop. This Road goes past the Toyota Dealership and changes name as it leaves Silsden to Holden Lane. Continue along this road carefully and the Venue car park is up the Hill on the Left.
