March 10, 200521 yr does any one know how big the rear disc on a 2002 sy250 should be as the brake pads are wearing funny they are leaving a lip near the top of the pad
March 10, 200521 yr Your disc on the Scorpa is much narrower,(only 14mm or 9/16" in width of surface area) to all the other discs. I'm sure you will find you have the wrong pads fitted.
March 10, 200521 yr I agree with Steveo (Jackass cast off?), my pads wear even, also, on the back of the packaging it lists the Scorpa SY as the only bike they are for. I suspect some other pads would be labled with the bikes they fit and if they fit more than one bike then it would say so on the rear.
March 10, 200521 yr That happened to me also one time. I had pads in from a Montesa (I know, sacrilegious) in my SY and wore the pads down until those "lips" on each pad touched together on the outside of the disc. It didn't allow proper pressure on the disc for good braking. I just filed down the lips and got another month out of the pads. I also agree, you got your pads mixed up. They'll work just fine though if you keep the "lips" filed down. All this talk about pads and lips is really opening ourselves up for the insinuating comments.
March 10, 200521 yr They'll work just fine though if you keep the "lips" filed down. I once knew a girl like that.
