July 1, 201115 yr can any one give me addvice on how to fit the seal on the clutch case of a 199A its on the out side of the case were the gear shaft comes out ive tryed puting it in but its really tight. and i dont want to damage me cover any help would be great
July 1, 201115 yr Get a sharp stanley knife or small file and put a leading edge on the seal housing in the case. Heat the casing, smear the seal in grease and it should push in easily
July 2, 201115 yr Author Get a sharp stanley knife or small file and put a leading edge on the seal housing in the case. Heat the casing, smear the seal in grease and it should push in easily ok ill try this thanks for your advice
