legal cub carb
what is the best legal pre65 carb that you can use on a cub? hope to get the bike ready for the pre65 next year but want to use the right carb.
you want the amal mk1 concentric for off the shelf stuff. the main issue will be getting the entry though about three years trying seems to be the going rate at the moment
i think there was a bit of 'upset' this year over the mk1 amals with a built in choke so keep it simple. surrey cycles will certainly set you on the path but a little tweaking may be req as all bikes are different esp cubs where a little cough or hesitation off closed throttle may need some work to clear or may not even be evident at all
Is that the 1.5 carb ?
