July 23, 201115 yr My c15 slips out of 1st under a light load. So far at least, it has not done this under hard throttle. There are no sounds or jumps, it just sort of slips into neutral. I pulled it apart and the cam plate had a little defect where it catches the spring in first gear so I cleaned it up square with a carbide end mill. It seemed OK but after getting hot it started slipping out again. The cam plate has no BSA or part number markings. I have ordered a new one. The bike was dead when I got it and so I did a total disassembly with replacement of any suspect parts. If it was anything obvious I probably would have seen it. It does not slip out of other gears or have any other shifting issues.
July 24, 201115 yr Jeez man you are hard core to get into that! Unfortunatly it does rather sound as if the actual engagement lugs on the gears sides are worn where they slide together and cam out under light load. Not that I know beans about that animal!
July 25, 201115 yr My c15 slips out of 1st under a light load. So far at least, it has not done this under hard throttle. There are no sounds or jumps, it just sort of slips into neutral. I pulled it apart and the cam plate had a little defect where it catches the spring in first gear so I cleaned it up square with a carbide end mill. It seemed OK but after getting hot it started slipping out again. The cam plate has no BSA or part number markings. I have ordered a new one. The bike was dead when I got it and so I did a total disassembly with replacement of any suspect parts. If it was anything obvious I probably would have seen it. It does not slip out of other gears or have any other shifting issues. Back in 1972 I ran a C15 on the road (I still have the bike) I had the same problem. When I went to the local BSA dealer he said change the lay shaft bush, I did and it stopped jumping out of 1st gear.
July 25, 201115 yr Author Back in 1972 I ran a C15 on the road (I still have the bike) I had the same problem. When I went to the local BSA dealer he said change the lay shaft bush, I did and it stopped jumping out of 1st gear. Would this be the bush in the main engine cases? Mine is the early style transmission,1960. The later ones seem to have more options for shimming. One odd thing about this transmission is that it has the wide ratio first gear and close ratio gears 3 through 4th.
July 25, 201115 yr Had a similar problem on my B40, adjusted the pawls on the plunger quadrant, been fine ever since. (20 years)
July 27, 201115 yr Author Had a similar problem on my B40, adjusted the pawls on the plunger quadrant, been fine ever since. (20 years) How do you adjust the pawls? I don't see anything to adjust?
July 28, 201115 yr How do you adjust the pawls? I don't see anything to adjust? Small screw from memory. Took off the second casing and put it in a vice (carefully) put shaft and quadrant in and adjusted. Locktited screws. If you have a new quadrant, these have variable quality. Have you got Rupert Ratio book ? ISBN 0-9535098-1-8
July 28, 201115 yr Author Small screw from memory. Took off the second casing and put it in a vice (carefully) put shaft and quadrant in and adjusted. Locktited screws. If you have a new quadrant, these have variable quality. Have you got Rupert Ratio book ? ISBN 0-9535098-1-8 I have the book but I can't find anything on adjusting the quadrant. I pulled the quadrant out but still do not see what to adjust. The two plungers look to be located in holes with no adjustment potential. The plate with the screw just seems to hold them in place. One interesting thing is that on one side, opposite the plunger, the flat surface is built up with about 1/16" of what looks like brazing. This area contacts the built up flats in the engine cases to limit the shifter travel. It is on the side that would limit travel on up shifts and I can't imagine why someone would do that. Thanks for your help with this.
July 30, 201115 yr Author I put in new cam plate. It looked a little different from the original, like it may engage further. It also had a newer part number than the original parts list. This is a distributor model. I did not see why it would make a difference but swapped the shift forks at the same time. The shifter now feels different when shifting, like more is going on. It worked OK during an hour ride so hopefully it is cured.
