Oil blowing out primary
When the bike is running the ATF comes out the primary filler plug (it's vented). I can't figure out how the primary is getting pressurized, I thought that if the crank seals were bad they would suck, not blow. Thoughts?
Somewhat recent experience with the Sherco's and the fuels suggeste this could go both ways, so seals are suspect I would think! :rolleyes:
Yeah, I thought that might be the case. Hope a local place has those size seals.
Piston goes down = positive pressure in crankcase. Piston goes up = negative pressure in crankcase.
Works both ways Dave.
P.S. It will pressurise the drive side because it is easier to push air from the crankcase through the seal during a downward stroke of the piston than it is to suck ATF back into the crankcase through the seal during an upward stroke.
Edited by TooFastTim
  • 2 weeks later...
New seals worked. Thanks.
