October 10, 201115 yr Hi all, Despite new oil pump / parts (design 1939...) Do need a "oil tap" or keep draining ~250ml before each ride.. Will kindly ask if you might have idea where to search for a tap hose/hose joint not restricting the oil flow...as tiny tap as possible, to be fitted close to the oil tank... Or I have to reweld a tap joint at the bottom of the oil tank... The "output" hose is hidden betwen the engine/gearbox... Father did assemble a rather big tap on his Pre-unit Triumph...where a lot of space is available.. Cheers, Edited October 10, 201115 yr by Pat
October 10, 201115 yr Disclaimer - could end in tears. http://www.trialsbits.co.uk/product_info.php?cPath=85_139_142&products_id=1596
October 10, 201115 yr Author Thanks a lot friend!! Perfect quick responce, will order tomorrow. Obviously there is a market for oil taps Cheers,
