Flatslide Carb
Has any one tried out a flatslide carb on their SHERCO, been offered one to try on the boys 03 bike ,just wondered if any one has any views on them? setup ,running problems etc. :o
Chaves had one on his late '03 bike. He said he liked it, but he is just looking for more power. I think the round bores are smoother and thats why Sherco stayed with them in '04.
Cheers
David has gone back to using the Keihin. It is also a flat slide. I have used Keihins on all of my bikes since "99" and like they way they perform better than the stock 26mm Dellorto. Just my preference, I think the bike runs smoother and stronger.
I just put one on my sons "04", he liked the way mine ran so he got a Keihin for Christmas.
Wayne
Wayne, Just ordered an 04 290 yesterday and would like to put the kehin on.. Can you tell me if I need to order any adaptors to accommadate the larger bore carb and also the jetting required @ sea level .......thanks D
D.
The stock manifold can be stretched to receive the larger Keihin, if it is warm and you use a little lube on the carb and the manifold it helps.
Here is the information that I sent another guy who was asking about installing a Keihin.
I am using a 45 pilot in mine and a 48 in my sons. The carb comes with a 45. For main jets I am running a 130 and have a 125 in the other one. I will probably go with 130
Thanks Wayne .......You have a PM...............D
