Lever will not disengage clutch
Trying to clean up some of my cables on my 72 OSSA MAR. Had the clutch cable off and now the lever even with lots of movement on the clutch activating lever on the case will not disengage the clutch. It is like something is not correct with the clutch actuating rod. I believe there is a ball in there but not sure where it is or if it could have fallen out. Any thoughts would be appreciated.
Jim in Folsom, CA
trials clutches often stick when not in use for a while some bikes do it after 1 day you need to warm it up run it around with clutch held in if it doesnt come off try pulling away in 3rd clutch in and apply rear brake at same time
warm bike up ride with clutch held in pull away in 3rd and apply rear brake
