November 12, 201115 yr hi all as anybody had the needel roller convertion done on the clutch arm? and what benafits do you get?
November 12, 201115 yr hi all as anybody had the needel roller convertion done on the clutch arm? and what benafits do you get? Yep have done so, benefit is much less friction to the rocker arm so the complete cluth action is very much improved. Highly recommanded. (With an oil bearing you can also get the construction better protected against water / debris too. I still use a felt washer soaked in oil to fill the gap.) Left modded clutch actuator, Right standard:
November 12, 201115 yr Author Yep have done so, benefit is much less friction to the rocker arm so the complete cluth action is very much improved. Highly recommanded. (With an oil bearing you can also get the construction better protected against water / debris too. I still use a felt washer soaked in oil to fill the gap.) Left modded clutch actuator, Right standard: ok thanks ill get it done cheers
