Which villiers engine
Hello everyone, right then, a pre65 James with a villiers 8e in, now I want to stay within the spirit of pre65 so, can anyone advise on the best engine eg stick with what I have or go for a 32a? Also what sort of mods can be done for better performance to either of these engines? Any advice greatly received just don't start on "the spirit" issue - each to his/her own, :agreed:
8e, 9e, 32a whichever you fancy. some prefer the alloy square barrel if so would have to be 9e or 32a. Best mod IMHO is to fit electronic ignition but as you want to stay within the spirit of pre65 then thats a no no isnt it? only other thing you can do is fit a efficient exhaust and air box which does help a lot.
The memories fading a bit but does a 32A legitimately qualify for Pre 65, can someone provide some info please
cheers
cheers
99% of the Villiers engined bikes in the Pre65 Scottish will be out if it's not LOL Then again there's the 37a debate :chairfall:
Hmmn, well that's a good start, so what can be done to the engine to give it a bit more grunt? Bore out? Skimmed head? Porting and Crankcase stuffing plates? Full circle crank? Oh also, good suppliers of James parts???
Edited by ben3010
Thanks Charlie, guess that route saves a lot of money, would just like to make it as good as poss without using say fiddle forks etc etc.
Hello there. Worth finding a Villiers 1H piston (225cc) and boring the barrel out. I have a 6E with a 1H +20 thou piston. There were works James's of the day modified in this manner and so were elibible for the "over 200cc class". And I'd say keep your bob weights - they'll find you grip in the mud!!!
