Keihin PWK 28 on 2011 290
As the title says, has anyone done it ? were the results worth it ? while my bike aint bad, it aint running as well as it could & i am sick of messing with the carb, your thoughts please.
yep did it thought it was a fair bit better standard this year.
have it in garage
have it in garage
Do you not use it now if it's in the garage ?
Should work ok but make sure it inclines/declines down to the piston. That model had the carb dtraight which seems to cause problems.
