Tlr 200 Re Bore
Can any one recomend someone who does a top class re bore for a Tlr 200? I'm out in N. Wales and it would be good to use someone local but it,s not Vital. Any help would be greatly appreciated.
Are there any oversize pistons available for TLR200's - Honda dont list any oversize pistons on their microfiche.?
There are also no oversize pistons listed for the XR200 - which has a similar top-end.
Perhaps there are some aftermarket parts available (eg Wiseco), probably more chance for the XR in the USA, but even then the piston will probably have to be modified to lower the compression to suit.
Thanks for your replies gents, Looks like i'll be contacting Gordon farley motorcycles then.
I do'nt suppose, HondaRs , you could let me have the address and phone number could you?
Many thanks.
Nigel Birkett rebored and put a trick piston in one of his employees TLR 200.
Give Birks a ring at Birkettmotosport 01229 716806 he will give you the answers.
Where do you get hold of a parts microfiche? Are they readily available or did you 'acquire' one.
I may need to source some parts for different Hondas and microfische with which to cross-reference parts would be a big help if they're available.
Wiseco do list oversize pistons for the 200 engines such as XR and XL - up to 67mm - but their catalogue doesn't list the TLR amongst them.
