showtime45 Posted January 9, 2012 Share Posted January 9, 2012 My Tl125 carb insulator took a crap. It's full of cracks & has been patched way too many times. What is everyone else using for a replacement? Thanks Quote Link to comment Share on other sites More sharing options...
tlrider Posted January 23, 2012 Share Posted January 23, 2012 I made my own, CNC machined from phenolic, TL125K profile, TL125S shield thickness also added an o-ring on the head side to eliminate the gasket and it has straight hole to help increase the air velocity sightly. I've had one on my bike for about 8 years now. I can see how many I have left if you're interested. Scooter Quote Link to comment Share on other sites More sharing options...
showtime45 Posted January 24, 2012 Author Share Posted January 24, 2012 I made my own, CNC machined from phenolic, TL125K profile, TL125S shield thickness also added an o-ring on the head side to eliminate the gasket and it has straight hole to help increase the air velocity sightly. I've had one on my bike for about 8 years now. I can see how many I have left if you're interested. Scooter Sure, when you get time. I have made one from Delrin but not sure how it will take the heat. Quote Link to comment Share on other sites More sharing options...
tlrider Posted January 24, 2012 Share Posted January 24, 2012 Sure, when you get time. I have made one from Delrin but not sure how it will take the heat. Delrin melts at 347 F, my material was speced at around 325 if I remember correctly. I know I cooked it at 315 for about 3 hrs and noticed no significant changes in dimensions or appearance. Try it and see how it holds up. Quote Link to comment Share on other sites More sharing options...
showtime45 Posted January 25, 2012 Author Share Posted January 25, 2012 Delrin melts at 347 F, my material was speced at around 325 if I remember correctly. I know I cooked it at 315 for about 3 hrs and noticed no significant changes in dimensions or appearance. Try it and see how it holds up. Thanks TL. I"ll find out this summer Quote Link to comment Share on other sites More sharing options...
