125 Fan Stays On
ar22
I have noticed that our 125 runs as soon as the bike is started
I presume this is not normal
should I change the stat or is it ok to run all the time ?
Edited by ar22
sounds like someones wired around the stat ,would be best to correct the problem before it causes a new problem
looked at the wiring and it all looks untouched
going out today, will see if it stays on all the time
I would check the Thermo-Switch in the radiator. Unplug one wire and see if the fan stops. If so, the switch may be shorted to run all the time.
you have just reworded what has just been written in previuos reply
now now boys, any help is good help
just put multimeter across switch
there is continuity when cold
switch is goosed
better get one ordered
thanks for all the replies
If the switch is in the radiator it screws in, if it's in a housing midway along the the hoses then to remove it you need to open up the metal clip piece then pull out the switch.
Replacing it is as simple as pushing back into the rubber sleeve & closing the clip back up. Did the switch come with a new sleeve & clip or do you need to reuse the original?
its the one for the pipe
yes it came with the housing, thats what confused me
initially I presumed, open the two clips and pull it out (or screw it out ?), then it arrives complete and no obvious way of the housing attaching
seems to have a lipped o ring which must just pop into the hose fitting
Sounds to be how I remember, use all the new parts to be safe.
When you open the clips you need to twist it to remove it
stat working, loom removed and new kill switch fitted
happy now
cheers
