Removing Switch Gear
while the tank is off I intend to remove the switch gear and fit a kill switch
presume I have to carefully split the loom and just leave the fan feed
which wire is the kill switch wire from the cdi ?
No, you can yank the harness and get the forked jumper for the fan circuit from Splatshop on the cheap. Kill wire is the single lead, black as I recall, dependant upon yers.
Edited by copemech
The kit for ditching the switchgear is very simple & easy to fit.
Have a look in the pinned manuals at the top & you'll find the instructions to do it
great job
got a harness sorted
cheers
great job
cheers
on second thoughts after looking under the tank I only need to cut and join 2 yellow wires and the harness is out, not hard to reverse although it will never be back on.
so I will do this myself tonight and save a few quid, then fit a new kill switch
You don't own a Beta so why cut the wiring, it's pretty easy to make your own kit-the photos should be enough to go off
agree
didnt do the deed last night, but your right, a straight yellow with a jumper wire on one end is all is needed, the original red can be reused
