Vauxhall Combo Van
Anyone know.... ??????
Can you get a trials bike in the back of a 61 plate Vauxhall Combo van.....?????
If so, do have to put it at an angle or turn the bars........ ?????
Thanks in advance.
Hiya
My Gas Gas goes in my combo no bother, i put it in corner to corner with the bars turned slightly, the handle bars are very close to the ridges in the roof when loading it in, and the rear mudguard is close to where the rear speakers would go but once in and strapped down it cleared everything and didn't move, I haven't tried putting the bike in backwards yet but i may try that to see if its better,
all in all i was supprised(and pleased) it went in
I hope that helps, if i can get a photo next time im out i'll post it up
Scott
Edited by Junglist
If it's a bit tight heightwise then put a strap round the bars and wheel spindle and compress the forks a bit.
Used them to get to Youth Nationals for a couple of years. It is tight but they do go in. The "NEW" one should be even better as it appears to be bigger.
Had Sherco's and a Scorpa in my Combo with no problems.
Back wheel first, diagonally across van and 2 straps from the bars to the loading hooks.
Looking at changing vans soon though, not sure what will replace the trusty Combo.
