Grphics
dose anyone now the best way to put grphic stickers on :rolleyes:
you and get two of your mates to help especially if it's the back mudguard
and lots of masking tape to keep it in place.
first you want to warm the area with a hair dryer and the sticker, start around the light and push all the bubbles out, you will need to peel the backing sheet of a little at atime and pull and stretch the sticker until it's all on be carefull not to rip the sticker near the seat as it's only thin.
hope this helps
also clean the plastic mudguard with some white spirits
where did you get the graphics from adam,i need some for my bike don,t know where to buy them from
Get stickers from your local trials bike stockist.
they are on oder from my local sherco dealer
why not try BVM :rolleyes::(
I mix part water and a bit of fairy liquid, then heat the sticker and the mudguard with a hairdryer, brush a little bit of fairy liquid on and then peel all the backing off of the sticker, put it on the mudguard then move it around on the water until its in the right place, then with your hairdryer move up and down the sticker so that the water evaporates and :rolleyes: a sticker very well fixed just where you want it.
Lloyd
