Worn Sprockets
If you reverse a hooked sprocket the teeth get ripped off almost instantly, if there is very slight wear and it is reversed is it OK ?
( It's not quite as worn as in following picture. )
http://www.dansmc.com/rearchain.HTM
Edited by B40RT
christ mate put some clothes on you wrong doer
If you reverse a hooked sprocket the teeth get ripped off almost instantly, if there is very slight wear and it is reversed is it OK ? ( It's not quite as worn as in following picture. )
Jeez man, you lost the teef an baws!
Bout time to take a pee too!
Edited by copemech
Jeez B40RT are you wearing Joanna Lumley's keks now? y'can see a bit of 'Old Holburn' peeking out as well :o
