March 18, 201214 yr hey guys can any one say what size socket fits the nut (left hand thread) on the final drive to change the front sprocket ? Thanks all Ian
March 19, 201214 yr Author Hi Bisby I will do what you suggest if nothing else helps, but I wanted to buy or borrow a socket that fits as Stecks suggested I now know its a 3/4 drive socket as 1/2 only go up to 32 mm. Thanks again Ian
March 19, 201214 yr Hi Bisby I will do what you suggest if nothing else helps, but I wanted to buy or borrow a socket that fits as Stecks suggested I now know its a 3/4 drive socket as 1/2 only go up to 32 mm. There are plenty of 1/2" drive 36AF sockets available. Try ebay, I would use an impact type with a full hex.
March 19, 201214 yr I just Googled 36mm socket and this lot popped up http://www.ebay.co.u...w=socket&_dmd=2 Some look as though they are made of mild cheese, but perhaps one of the impact sockets might last long enough to get the sprocket off, and with a bit of luck, back on again. Some of them are driven by 1/2" drives, but I think I'd go for a bigger drive than that... And on the up side, if you get one, we can all borrow it...
March 20, 201214 yr never thought to look on e by might have to treet bike to a new part, thanks. steve
April 2, 201214 yr Author I must be getting very old as I´v found a Socket in the Trials-Tool-Box. Suddenly rememberd seeing one there (things like taht are VERY strange and sometimes a bit worrying) !
